Zum Hauptinhalt wechseln
LG G Pad 8.3 4G Back Panel Replacement
Was du brauchst
  1. LG G Pad 8.3 4G Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Back Panel Replacement: Schritt 2, Bild 1 von 3 LG G Pad 8.3 4G Back Panel Replacement: Schritt 2, Bild 2 von 3 LG G Pad 8.3 4G Back Panel Replacement: Schritt 2, Bild 3 von 3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 455
