Einleitung
Before being able to do anything inside your LG G Pad, you will need to remove the back panel. Follow this guide to do so.
Was du brauchst
With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
Take the spudger and slide it around the perimeter of the device.
Pull gently on the edges to get the panel to pop up.
Fast fertig!
Abschluss
