Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If you need to replace a component inside the LG G Pad 8.3, you will need to remove the back panel. This guide will teach you how to remove the back panel.
  1. With the tablet face down, pull the SD card slot cover out. Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. Insert a plastic opening tool in the small crevasse between the screen and the back panel. Pry the screen away from the back panel. Repeat this on each edge of the device.
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. After using the plastic opening tools, pry the device open with your hands. Remove the back panel from the screen.
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
Abschluss
Raenicia Haworth
375 Reputation
1 Anleitung geschrieben
CSU Fullerton, Team 1-6, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 111
