Einleitung
If your front facing camera is not working properly, it may be time to replace it. This guide will show you how to replace the front facing camera.
Was du brauchst
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
Remove the ribbon cable from the device.
Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
Use a plastic opening tool to lift the front facing camera out of the device.
Eine weitere Person hat diese Anleitung absolviert.
