Zum Hauptinhalt wechseln
LG G Pad 8.3 Front Facing Camera Replacement
Was du brauchst
  1. LG G Pad 8.3 Front Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 2, Bild 1 von 3 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 2, Bild 2 von 3 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 3, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Front Facing Camera Replacement, Speaker: Schritt 4, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement, Speaker: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Front Facing Camera Replacement, Battery: Schritt 6, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
  7. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 7, Bild 1 von 3 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 7, Bild 2 von 3 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 7, Bild 3 von 3
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 8, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
  9. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 9, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 9, Bild 2 von 2
    • Unhook the battery from the top of the device.
  10. LG G Pad 8.3 Front Facing Camera Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Unhook the small yellow ribbon on top of the motherboard.
  11. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 11, Bild 1 von 1
    • Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
  12. LG G Pad 8.3 Front Facing Camera Replacement: Schritt 12, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement: Schritt 12, Bild 2 von 2
    • Use a plastic opening tool to lift the motherboard out of the device.
  13. LG G Pad 8.3 Front Facing Camera Replacement, Front Facing Camera: Schritt 13, Bild 1 von 2 LG G Pad 8.3 Front Facing Camera Replacement, Front Facing Camera: Schritt 13, Bild 2 von 2
    • Use a plastic opening tool to lift the front facing camera out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
CSU Fullerton, Team 1-6, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,603
