Einleitung
If your speaker isn't working, it may be time to replace it. This guide will show you how to replace the speaker.
Ersatzteile
Kein Ersatzteil erforderlich.
With the tablet face down, pull out the SD card slot cover.
Using a Philips #000 screwdriver, remove the 3mm screw in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry open the device with your hands, removing the back panel from the screen.
Remove the four 3 mm Phillips screws that hold down the speaker.
4 weitere Nutzer haben diese Anleitung absolviert.
