Zum Hauptinhalt wechseln
LG G Pad 8.3 Volume Control Buttons Replacement
Was du brauchst
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: Schritt 1, Bild 1 von 2 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Volume Control Buttons Replacement: Schritt 2, Bild 1 von 3 LG G Pad 8.3 Volume Control Buttons Replacement: Schritt 2, Bild 2 von 3 LG G Pad 8.3 Volume Control Buttons Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Volume Control Buttons Replacement: Schritt 3, Bild 1 von 2 LG G Pad 8.3 Volume Control Buttons Replacement: Schritt 3, Bild 2 von 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: Schritt 4, Bild 1 von 2 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: Schritt 4, Bild 2 von 2
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
Abschluss
CSU Fullerton, Team 1-6, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,072
