Zum Hauptinhalt wechseln
LG G Pad F 7.0 Speaker Replacement
Was du brauchst
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 LG G Pad F 7.0 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: Schritt 2, Bild 1 von 2 LG G Pad F 7.0 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: Schritt 3, Bild 1 von 3 LG G Pad F 7.0 Speaker Replacement: Schritt 3, Bild 2 von 3 LG G Pad F 7.0 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jose Hurtado
329 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-5, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 186
