Einleitung
This covers how to replace the speaker on a LG G Pad F 7.0
Was du brauchst
Open up the SIM port, on the top right corner (screen face down).
Press the SIM card (white plastic) to pop it out.
Remove SIM card and set aside.
Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
Locate the LG G Pad F 7.0 speaker
Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
Remove old speaker and replace with a new one
2 weitere Nutzer:innen haben diese Anleitung absolviert.
