Zum Hauptinhalt wechseln
LG G Pad F 8.0 Battery Replacement
Was du brauchst
  1. LG G Pad F 8.0 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 LG G Pad F 8.0 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Battery Replacement: Schritt 2, Bild 1 von 2 LG G Pad F 8.0 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Battery Replacement: Schritt 4, Bild 1 von 1
    • Pry up on the multi-color ribbon with the iFixit opening tool to disconnect it.
  5. LG G Pad F 8.0 Battery Replacement: Schritt 5, Bild 1 von 2 LG G Pad F 8.0 Battery Replacement: Schritt 5, Bild 2 von 2
    • Use the iFixit opening tool to pry up the four edges of the battery.
    • Remove the battery from the tablet.
Abschluss
Noah Trevino
353 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 246
