Zum Hauptinhalt wechseln
LG G Pad F 8.0 Motherboard Replacement
Was du brauchst
  1. LG G Pad F 8.0 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 LG G Pad F 8.0 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Motherboard Replacement: Schritt 2, Bild 1 von 2 LG G Pad F 8.0 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Motherboard Replacement: Schritt 4, Bild 1 von 3 LG G Pad F 8.0 Motherboard Replacement: Schritt 4, Bild 2 von 3 LG G Pad F 8.0 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use the iFixit opening tool to disconnect the multicolor wire cables from the motherboard.
    • Disconnect the top of the orange ribbon cable from the motherboard.
    • Detach the front facing camera ribbon cable from the motherboard.
  5. LG G Pad F 8.0 Motherboard Replacement: Schritt 5, Bild 1 von 3 LG G Pad F 8.0 Motherboard Replacement: Schritt 5, Bild 2 von 3 LG G Pad F 8.0 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the seven 2 mm screws using a Phillips #0 screwdriver.
    • Use the iFixit opening tool and pry up on the motherboard to remove it.
Abschluss
Angel Padilla
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 113
