Zum Hauptinhalt wechseln
LG G Pad F 8.0 Screen Replacement
Was du brauchst
  1. LG G Pad F 8.0 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 LG G Pad F 8.0 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Screen Replacement: Schritt 2, Bild 1 von 2 LG G Pad F 8.0 Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to pry the plastic backing off of the internal block.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
Abschluss
Noah Trevino
353 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 336
