Einleitung
A battery replacement is actually quite simple to do for this tablet requiring minimum time and a few handy tools. You'll soon be able to go from no battery life to hours with this easy guide.
Was du brauchst
Power off the device before starting battery replacement.
Remove SD card and SIM Card.
With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
Gently pull the back cover away from the adhesive on the battery.
Slowly and gently lift the power cable upwards.
Unscrew the 4 screws keeping the battery in place, set aside.
17 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
Thank you perfect
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
2 years on they're $14
