Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A battery replacement is actually quite simple to do for this tablet requiring minimum time and a few handy tools. You'll soon be able to go from no battery life to hours with this easy guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power off the device before starting battery replacement.
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. Gently pull the back cover away from the adhesive on the battery. It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Slowly and gently lift the power cable upwards. Unscrew the 4 screws keeping the battery in place, set aside. Unscrew the 4 screws keeping the battery in place, set aside.
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  5. Remove  the battery by pulling up gently.
    • Remove the battery by pulling up gently.
Abschluss
15 weitere Nutzer haben diese Anleitung absolviert.
Calvin Hodgson
1.086 Reputation
4 Anleitungen geschrieben
Thank you perfect
Robert Begliutti - Antwort
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - Antwort
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
Calvin Hodgson -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 31
Letzten 30 Tage: 172
Insgesamt: 11,544
