Zum Hauptinhalt wechseln
LG G Pad X 8.0 Motherboard Replacement
Was du brauchst
  1. LG G Pad X 8.0 Motherboard Replacement, Removing Backplate: Schritt 1, Bild 1 von 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: Schritt 2, Bild 1 von 2 LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: Schritt 2, Bild 2 von 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: Schritt 3, Bild 1 von 3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: Schritt 3, Bild 2 von 3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: Schritt 3, Bild 3 von 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Motherboard Replacement, Removing the Battery: Schritt 4, Bild 1 von 1
    • Remove the battery by pulling up gently.
  5. LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: Schritt 5, Bild 1 von 3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: Schritt 5, Bild 2 von 3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: Schritt 5, Bild 3 von 3
    • Pry the connector for the camera up.
    • Pry the connector for the USB module up.
    • Pry the cable connecting the metal circle.
  6. LG G Pad X 8.0 Motherboard Replacement, Remove screws: Schritt 6, Bild 1 von 3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: Schritt 6, Bild 2 von 3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: Schritt 6, Bild 3 von 3
    • Unscrew the 3 screws holding the USB module down.
    • Unscrew the 2 screws keeping the motherboard in place.
    • Finally, the two screws for the micro USB port.
  7. LG G Pad X 8.0 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently lift up the display connector.
    • Be careful, too much pressure can cause the digitizer/screen to crack as it is right below the metal.
  8. LG G Pad X 8.0 Motherboard Replacement, Removing the Motherboard: Schritt 8, Bild 1 von 1
    • Remove the motherboard by pulling it straight up and away from the tablet body.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
1.146 Reputation
3 Anleitungen geschrieben
2 Kommentare
Would my motherboard to my pad be no good due to water damage it’s been 3 months still won’t turn on. The little sticker is pink still but my battery smells burnt. Could I take out the mother and use some air dust ?
Joe - Antwort
You may need to replace the battery as it sounds like it shorted out. A burnt smell more than likely means the battery is damaged.
Have you tried replacing the battery yet?
[deleted] -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,829
