Zum Hauptinhalt wechseln
LG G Vista Battery Replacement
  1. LG G Vista Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off.
  2. LG G Vista Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
Abschluss
Make sure battery is perfectly fitted into it's spot before replacing the back cover. Power phone on to ensure the new battery is working properly.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 624
