Einleitung
This guide will walk you through with replacing the motherboard of you LG G Vista. You will need tweezers, a Phillips screwdriver #000, and a small plastic spudger, or your thumb nail.
Was du brauchst
Remove the back cover by gently prying open the case of the device from the charging port.
Lift the battery out of its place by prying up from the small notch at the base of the battery.
Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
2 weitere Personen haben diese Anleitung absolviert.
