Zum Hauptinhalt wechseln
LG G Watch Motherboard Replacement
Was du brauchst
  1. LG G Watch Motherboard Replacement, Wristband: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Motherboard Replacement: Schritt 2, Bild 1 von 2 LG G Watch Motherboard Replacement: Schritt 2, Bild 2 von 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Motherboard Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Motherboard Replacement: Schritt 4, Bild 1 von 2 LG G Watch Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Motherboard Replacement, Gasket: Schritt 5, Bild 1 von 1
    Kaufen
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 LG G Watch Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Motherboard Replacement: Schritt 7, Bild 1 von 2 LG G Watch Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
is it possible to replace the battery which is in the board?
Vassago U7 (VassagoU7) - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,066
