Einleitung
This guide will show you how to remove the battery housing for the LG G Watch R.
Was du brauchst
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Use a plastic opening tool to pry the battery out of the device.
Pry the battery housing from the top right corner using a spudger.
Once loosened, remove the battery housing.
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hi there, do you know where can i buy the battery housing? Thank you..
