Zum Hauptinhalt wechseln
LG G Watch R Motherboard Replacement
Was du brauchst
  1. LG G Watch R Motherboard Replacement, Back Case: Schritt 1, Bild 1 von 2 LG G Watch R Motherboard Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 LG G Watch R Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: Schritt 5, Bild 1 von 2 LG G Watch R Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Westley Courchene
3.341 Reputation
14 Anleitungen geschrieben
USF Tampa, Team 1-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Mitglieder
3 Kommentare
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Antwort
Where do I buy a replacement motherboard from??
Brandon Reznik - Antwort
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 3,150
