Zum Hauptinhalt wechseln
LG G Watch R Power Button
Was du brauchst
  1. LG G Watch R Power Button, Back Case: Schritt 1, Bild 1 von 2 LG G Watch R Power Button, Back Case: Schritt 1, Bild 2 von 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Power Button: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Power Button: Schritt 3, Bild 1 von 1
    • Remove the back case.
  4. LG G Watch R Power Button, Motherboard: Schritt 4, Bild 1 von 2 LG G Watch R Power Button, Motherboard: Schritt 4, Bild 2 von 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Power Button: Schritt 5, Bild 1 von 2 LG G Watch R Power Button: Schritt 5, Bild 2 von 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Power Button: Schritt 6, Bild 1 von 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Power Button, Battery Replacement: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Power Button, Battery Housing Replacement: Schritt 8, Bild 1 von 2 LG G Watch R Power Button, Battery Housing Replacement: Schritt 8, Bild 2 von 2
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
  9. LG G Watch R Power Button, Power Button: Schritt 9, Bild 1 von 3 LG G Watch R Power Button, Power Button: Schritt 9, Bild 2 von 3 LG G Watch R Power Button, Power Button: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • On the power button, locate a small grey washer on the interior side of the watch.
    • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Westley Courchene
3.410 Reputation
14 Anleitungen geschrieben
USF Tampa, Team 1-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 2,704
