Zum Hauptinhalt wechseln
LG G Watch Wristband Replacement
Was du brauchst
  1. LG G Watch Wristband Replacement, Wristband: Schritt 1, Bild 1 von 1
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Wristband Replacement: Schritt 2, Bild 1 von 2 LG G Watch Wristband Replacement: Schritt 2, Bild 2 von 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Deja Miller
462 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 2-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 16
Insgesamt: 838
