Einleitung
Having trouble charging your phone? Here is a guide to replace a faulty charger port. Make sure to keep track of the parts you remove. The phone has many small screws, antennae, and ribbons that need to be worked with.
Was du brauchst
Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
After removing the outer phone case, you will need two Phillips head bits. One J0 and one J000 size.
There are 11 silver screws for which you have to use J0 head bits, and 1 small black screw for which you have to use a J000 head bit.
There is a clip on the upper left side of the upper panel. Use the plastic opening tool to pry the clip off of the phone.
There are ribbons that need to be removed as well. Be sure to carefully pry them off of the board
The bottom inside panel should pry back easily after you take out the screws. Again, if the panel does not pull off easily, you may have missed a screw.
There are several clips and circuits that need to be released. They are circled in the images above. Be careful not to break any of the attached ribbon or wires. (circle ribbons etc.)
After you have disconnected all of the ribbon and antennae connections, you can remove the board. Gently pry the board up from the bottom of the case and slide it back out.
Make sure to remove all ribbon connectors from the board prior to removing the board.
Eine weitere Person hat diese Anleitung absolviert.
