Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
  1. Remove the back cover by placing your fingernail in the crease between the cover and the charging port. Pry upward and the cover should pop off easily. Pry upward and the cover should pop off easily.
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay. Now you are able to replace the battery with a new one. Now you are able to replace the battery with a new one.
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
    • Now you are able to replace the battery with a new one.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Aung Myin Thu Mayet
632 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Mitglied von UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,890
