Was du brauchst
Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
Pry upward and the cover should pop off easily.
Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
Now you are able to replace the battery with a new one.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
