Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
The rear-facing camera may be causing problems due to either the ribbon cable not being connected properly or because the camera is broken. This guide should help you fix both problems.
  1. Power off your phone before beginning disassembly. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. Lift the back cover to release the rest of the plastic clips and remove it. In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess. Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. Lift the battery out of its recess and remove it. Lift the battery out of its recess and remove it.
    • Lift the battery out of its recess and remove it.
  5. Remove the four Phillips #00 screws (4 mm length).
    • Remove the four Phillips #00 screws (4 mm length).
  6. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover. Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. Remove the eight Phillips #00 screws (4 mm length).
    • Remove the eight Phillips #00 screws (4 mm length).
  9. Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard. Pry up the motherboard cover to open the plastic clips which hold the cover in its place. The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. Carefully lift the right edge of the motherboard cover. The remaining plastic clips should open during this process or can be unhinged easily by hand. Remove the motherboard assembly.
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. Use a spudger to pry up and disconnect the display flex cable. Use a spudger to pry up and disconnect the display flex cable.
    • Use a spudger to pry up and disconnect the display flex cable.
  12. Use a spudger to pry up and disconnect the digitizer flex cable. Use a spudger to pry up and disconnect the digitizer flex cable.
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. Use a spudger to pry up and disconnect the rear camera flex cable. Use a spudger to pry up and disconnect the rear camera flex cable.
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. Use a spudger to pry up and disconnect the front camera flex cable. Use a spudger to pry up and disconnect the front camera flex cable.
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. During these next few steps, make sure to avoid damaging the flex cables you disconnected. Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways. Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. Grab the top section of the motherboard and carefully lift it out of the phone. Grab the top section of the motherboard and carefully lift it out of the phone.
    • Grab the top section of the motherboard and carefully lift it out of the phone.
  18. Take the plastic opening tool and remove the rear-facing camera by wedging it into the sides and lifting up The rear-facing camera is kept in place with a double-sided tape, so it may take some time and effort to get it out. Attack it from all sides
    • Take the plastic opening tool and remove the rear-facing camera by wedging it into the sides and lifting up
    • The rear-facing camera is kept in place with a double-sided tape, so it may take some time and effort to get it out. Attack it from all sides
  19. Remove the old rear-facing camera
    • Remove the old rear-facing camera
Abschluss
25 weitere Nutzer haben diese Anleitung absolviert.
Shannon
1.571 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-3, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 1-3, Duarte Fall 2014
UMASSD-DUARTE-F14S1G3
4 Mitglieder
10 Anleitungen geschrieben
perfect. Camera had stopped functioning on my G3 (due to some clumsiness on my part). Followed the steps and disconnect camera ribbon, then reconnected and reassembled. Now all functioning perfectly.
Andy Corps - Antwort
how was it not functioning? Mine suddenly wont even detect that there is a back camera and I am debating whether to try this and risk ruining the phone or just spending the extra cash and having it done professionally since I can't get a new one until april.
Claire Robbins -
Mine the camera started crashing 'unfortunately camera stopped' but the selfie cam worked. Reset did nothing have to try this.
Gad Mugane - Antwort
Will the phone work with out the camera in it?
Mike Kizer - Antwort
Excellent guide.    Bad auto focus, replaced -> works !
Would add in step 6, top panel is held on by small plastic tabs on the edges.
As with all electronic dis/assembly, make sure take appropriate anti-static precautions.
Jonathan Ling - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 24
Insgesamt: 19,959
