1. While holding the battery release button, pull the bottom end of the phone out of the body. While holding the battery release button, pull the bottom end of the phone out of the body.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray. Press inward with some force to eject the tray. Pull the sim card tray out of the phone.
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. Remove the two 5.5mm Phillips #00 screws from the base of the phone. Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  5. Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  6. Insert the Spudger into the now open space between the body and screen. Push inward to separate the screen even more.
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  7. Peel the screen away from the body.  The two parts should be completely separated. Peel the screen away from the body.  The two parts should be completely separated.
    • Peel the screen away from the body. The two parts should be completely separated.
  8. Locate the auxiliary port on the top right of the phone
    • Locate the auxiliary port on the top right of the phone
    • Using a finger, carefully take the port out
    • Replace the old auxiliary port with a new one by orienting the hole towards the top of the phone and the gold ribbon to the left (as shown in the picture).
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Joshua Zalmanowitz
1.550 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-2, Forte Fall 2016 Mitglied von Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Mitglieder
16 Anleitungen geschrieben
I saw a video where someone used a guitar pick as the plastic opening tool, seems safer to me. And that person also had a great idea to shove a pencil in the battery bay to apply a separating force, so that as you work the seam with a guitar pick, the the two halves will naturally want to separate.
Adam Mizban - Antwort
Hi, I have two LG G5 phone. Let's call them
A & B.
So , B overheats and the battery last less than an hour. So I took the battery from A and I put it in B and I put the B battery in the A. Results: B still overheats and not the A ??? I also left the connector blocks on the batteries when I did the switching. So what could be the cause of this?
Julie Desruisseaux - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 75
Insgesamt: 3,650
