Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will help you through the steps to replace your LG G5 battery. The LG G5 is built to allow simple battery replacement, so you'll only need your hands for this process! Use this guide if your battery will not hold charge.
If your battery is swollen, take appropriate precautions.
Werkzeuge
Keine Werkzeuge angegeben.
  1. Power down the phone by holding the power button for several seconds. While holding the battery release button, pull the bottom end of the phone out of the body. While holding the battery release button, pull the bottom end of the phone out of the body.
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  3. Separate the battery from bottom half. Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
Abschluss
16 weitere Nutzer haben diese Anleitung absolviert.
Sam Goldheart
411.700 Reputation
547 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
124 Mitglieder
11.617 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 27
Letzten 30 Tage: 138
Insgesamt: 10,913
