Einleitung
Use this guide to remove your LG G5's front panel assembly. This involves separating the screen from the body of the phone. If you are trying to replace any components within the LG G5, you'll need to follow this guide first!
  1. While holding the battery release button, pull the bottom end of the phone out of the body. While holding the battery release button, pull the bottom end of the phone out of the body.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray. Press inward with some force to eject the tray. Pull the sim card tray out of the phone.
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two 5.5mm Phillips #00 screws from the base of the phone. Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  5. Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  6. Insert the Spudger into the now open space between the body and screen. Push inward to separate the screen even more.
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  7. Peel the screen away from the body.  The two parts should be completely separated. Peel the screen away from the body.  The two parts should be completely separated.
    • Peel the screen away from the body. The two parts should be completely separated.
Abschluss
Now you can access all the inner components of the phone!
28 weitere Nutzer haben diese Anleitung absolviert.
Joshua Zalmanowitz
1.574 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-2, Forte Fall 2016 Mitglied von Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Mitglieder
16 Anleitungen geschrieben
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - Antwort
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - Antwort
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - Antwort
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 107
Insgesamt: 7,487
