Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide requires specialized equipment and microsoldering knowledge.
Ersatzteile
    • Insert wisdom here.
  1. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
Abschluss
MovilOne
2.350 Reputation
16 Anleitungen geschrieben
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Antwort
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Antwort
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 29
Insgesamt: 3,241
