Zum Hauptinhalt wechseln
LG GW910 Camera Replacement
Was du brauchst
  1. LG GW910 Camera Replacement, Motherboard: Schritt 1, Bild 1 von 2 LG GW910 Camera Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Camera Replacement: Schritt 2, Bild 1 von 2 LG GW910 Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Camera Replacement: Schritt 4, Bild 1 von 3 LG GW910 Camera Replacement: Schritt 4, Bild 2 von 3 LG GW910 Camera Replacement: Schritt 4, Bild 3 von 3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Camera Replacement: Schritt 5, Bild 1 von 1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Camera Replacement: Schritt 6, Bild 1 von 1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Camera Replacement: Schritt 7, Bild 1 von 3 LG GW910 Camera Replacement: Schritt 7, Bild 2 von 3 LG GW910 Camera Replacement: Schritt 7, Bild 3 von 3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Camera Replacement, Camera: Schritt 8, Bild 1 von 2 LG GW910 Camera Replacement, Camera: Schritt 8, Bild 2 von 2
    • Disconnect the connector using the metal spudger.
    • Peel back the tape on the side.
    • Replacement tape might be needed.
  9. LG GW910 Camera Replacement: Schritt 9, Bild 1 von 3 LG GW910 Camera Replacement: Schritt 9, Bild 2 von 3 LG GW910 Camera Replacement: Schritt 9, Bild 3 von 3
    • Pry open the two plastic hooks using the metal spudger tool.
    • Crack open the black plastic cover using the metal spudger tool. The cover should be easily turned over.
    • The connector might get stuck in the opening while turning over the cover. Twist the connector if needed.
  10. LG GW910 Camera Replacement: Schritt 10, Bild 1 von 2 LG GW910 Camera Replacement: Schritt 10, Bild 2 von 2
    • Remove the camera unit by prying on it.
    • Adhesive will be needed for reassembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonas Ke
492 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G6, Hovde Fall 2018 Mitglied von IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 135
