Einleitung
This guide will assist you while you take your phone apart. This disassemble is not a very difficult task. There will be a few connectors that will be disconnected during the process. Make sure to be cautious with them so they do not rip. There are many little screw that will be taken off the phone. Make sure that you have a clean and organized work space.
Was du brauchst
Remove the back cover by firmly pressing the triangle and push upwards.
Lift the bottom section to remove the cover.
Pry off the connector using the iFixit opening tool to remove the communication board.
Pry off the connectors using the iFixit opening tool.
Disconnect the antenna using the iFixit opening tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
