Zum Hauptinhalt wechseln
LG Incite Camera Replacement
Was du brauchst
  1. LG Incite Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Camera Replacement: Schritt 2, Bild 1 von 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Camera Replacement: Schritt 3, Bild 1 von 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Camera Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Camera Replacement: Schritt 5, Bild 1 von 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Camera Replacement: Schritt 6, Bild 1 von 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Camera Replacement, Camera: Schritt 7, Bild 1 von 2 LG Incite Camera Replacement, Camera: Schritt 7, Bild 2 von 2
    • Locate the camera near the upper-left corner and use the metal tweezers to carefully detach the black tab.
  8. LG Incite Camera Replacement: Schritt 8, Bild 1 von 3 LG Incite Camera Replacement: Schritt 8, Bild 2 von 3 LG Incite Camera Replacement: Schritt 8, Bild 3 von 3
    • Carefully slide the metal tweezers underneath the camera in order to lift it out.
    • Do not puncture the gold lining surrounding the camera.
    • The camera is glued in place, so there may be a slight resistance.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kimberly Kha
163 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-18, Maness Spring 2013 Mitglied von Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 560
