Einleitung
If your screen protector is cracked or prevents touch commands to the display, use this guide to replace your screen protector.
Was du brauchst
Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
Carefully use the plastic opening tool to pry the motherboard from the front screen.
Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
Remove the 5mm Phillips #00 screw on the top right of the phone.
Carefully pull the ribbon cable upward and away from the front screen display.
Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
