Zum Hauptinhalt wechseln
LG K10 Battery Replacement
Was du brauchst
Einführungsvideo
  1. LG K10 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert thumb or any other thin flat object into the slight indent on the right of the phone.
  2. LG K10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Gently push against to the sides of the phone to open the case.
  3. LG K10 Battery Replacement: Schritt 3, Bild 1 von 1
    • Push against the battery on the bottom, to take off the battery.
  4. LG K10 Battery Replacement: Schritt 4, Bild 1 von 1
    • Align the new battery with the 4 bronze metals on the top left side of the battery and insert the new battery.
  5. LG K10 Battery Replacement: Schritt 5, Bild 1 von 1
    • Push the bottom case in firmly with both hands to secure the case back onto the phone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.454 Reputation
378 Anleitungen geschrieben
2 Kommentare
Lg k10 battery is slow charging. What will i do?
pawan kumar lal - Antwort
Lg k10 mobile is very good. But its slow charging. It takes more time to charging. What is problem?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 6,480
