Einleitung
If the display screen of your LG K10 got broken or cracked, please follow this repair guide to replace it.
Was du brauchst
Videoanleitungen
Fast fertig!
Abschluss
23 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Eric, thanks for the guide to replacing the LG K10 screen. I was about to commit to doing one, but when I went to buy a part, the first thing I found was the glass cover over the display, which of course is way cheaper than the whole display. Can you comment about changing out just the glass?
TheGear - Antwort
Hello,
Thanks for the awsome guide.
Has anyone had overheating problems on this phone after changing the display?
Cheers
André Santos - Antwort
Thanks for the guid. I wish I saw this before i had it sent to a company to fix it. If anyone is seeing this. Don't make the same mistake as I did. I bought a case that just had grip. Buy a coverware case. They are super durable. I dropped my phone on phone call and it shattered with the original case. I dropped my phone down a flite of stairs with the coverware case and it survived without any damage.
Samuel White - Antwort
I have a problem after installing a new screen. I followed the same steps like the video . The problem is that the digitizer is not working at all. The screen works fine but not the touch function. I have tried 2 different new screens but the prpblem remains. Do I have to glue the lcd connector to the middle frame?
Filippos Vlachos - Antwort
Se o celular cair dentro da agua isso funciona?
lg680023 - Antwort
