Zum Hauptinhalt wechseln
LG K10 Display Screen Replacement
Was du brauchst
Videoanleitungen
Abschluss
23 weitere Personen haben diese Anleitung absolviert.
Witrigs
70.190 Reputation
377 Anleitungen geschrieben
5 Kommentare
Eric, thanks for the guide to replacing the LG K10 screen. I was about to commit to doing one, but when I went to buy a part, the first thing I found was the glass cover over the display, which of course is way cheaper than the whole display. Can you comment about changing out just the glass?
TheGear - Antwort
Hello,
Thanks for the awsome guide.
Has anyone had overheating problems on this phone after changing the display?
Cheers
André Santos - Antwort
Thanks for the guid. I wish I saw this before i had it sent to a company to fix it. If anyone is seeing this. Don't make the same mistake as I did. I bought a case that just had grip. Buy a coverware case. They are super durable. I dropped my phone on phone call and it shattered with the original case. I dropped my phone down a flite of stairs with the coverware case and it survived without any damage.
Samuel White - Antwort
I have a problem after installing a new screen. I followed the same steps like the video . The problem is that the digitizer is not working at all. The screen works fine but not the touch function. I have tried 2 different new screens but the prpblem remains. Do I have to glue the lcd connector to the middle frame?
Filippos Vlachos - Antwort
Se o celular cair dentro da agua isso funciona?
lg680023 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 19
Letzte 30 Tage: 34
Insgesamt: 15,890
