Zum Hauptinhalt wechseln
LG K10 Rear Camera Replacement
Was du brauchst
Einführungsvideo
  1. LG K10 Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 1
    • Power off the device
    • Remove the backing
  2. LG K10 Rear Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery
  3. LG K10 Rear Camera Replacement: Schritt 3, Bild 1 von 1
    • Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
  4. LG K10 Rear Camera Replacement: Schritt 4, Bild 1 von 1
    • With a pick lift the side of the phone, in order to remove the backside
    • Repeat this step on all sides of the phone
  5. LG K10 Rear Camera Replacement: Schritt 5, Bild 1 von 1
    • Once the back is completely off, you now have complete access to the rear camera
    • You also now have access to the rear/ front speakers, and motherboard
  6. LG K10 Rear Camera Replacement: Schritt 6, Bild 1 von 1
    • Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Remove the rear facing camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Witrigs
70.190 Reputation
377 Anleitungen geschrieben
Ein Kommentar
Can you upgrade the original camera with say a G5 camera?
Larry Smith - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 14
Letzte 30 Tage: 14
Insgesamt: 1,672
