Zum Hauptinhalt wechseln
LG K20 PLUS Midframe Replacement
Was du brauchst
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: Schritt 1, Bild 1 von 2 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: Schritt 1, Bild 2 von 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: Schritt 2, Bild 1 von 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: Schritt 3, Bild 1 von 2 LG K20 PLUS Midframe Replacement: Schritt 3, Bild 2 von 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Abschluss
Patrick
6.586 Reputation
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 73
