Zum Hauptinhalt wechseln
LG K30 Rear Facing Camera Replacement
Was du brauchst
  1. LG K30 Rear Facing Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LG K30 Rear Facing Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Rear Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Rear Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Rear Facing Camera Replacement: Schritt 5, Bild 1 von 2 LG K30 Rear Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Rear Facing Camera Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Rear Facing Camera Replacement: Schritt 7, Bild 1 von 2 LG K30 Rear Facing Camera Replacement: Schritt 7, Bild 2 von 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 8, Bild 1 von 2 LG K30 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 8, Bild 2 von 2
    • Only pry on the tab, not the connector itself.
    • Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
    • Remove the rear-facing camera.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 529
