Einleitung
Have you received a “Warning: Camera Failed” message or something similar? Is your camera lens on your LG K30 Phone cracked. These are signs that your LG Phone is in need a camera replacement.
Use this guide to install a new rear facing camera. As always, please ensure your phone is powered off completely.
Was du brauchst
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to detach the battery connector from the logic board.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Remove the motherboard assembly from the display assembly with the a spudger or hand.
Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
Remove the rear-facing camera.
