Einleitung
Changing a phone's battery is necessary after some time since the battery life gets degraded over the years. This process has gotten more complicated the more modern the phones get. Fortunately, replacing the battery of this phone is really simple since it can be easily removed by the user and does not require any type of special skill. Therefore, in this guide, you will learn how to replace an LG K4 phone's battery properly.
Was du brauchst
First, turn off the phone to prevent any electrical issues or possible storage loss.
Open the back of the phone carefully. You can use your hands or any plastic opener tools; simply stick one nail (or plastic opener) on the tiny dent shown and carefully pull it out.
There are many ways to remove the back cover. The best way is to use this tiny dent on the side to avoid any cracks.
Once you remove the back cover, remove the old battery from the back of the phone by grabbing the lower part of the battery as shown in the picture. Once you do this leave the battery aside.
Install the new battery. First, slide it up to where the four pins are located.
Reattach the back cover, make sure the headphone jack, charging port and volume buttons all fit with the cover.
Turn on the phone and check if the battery charges too. This step is important to check if the battery was properly placed or functions properly.
To reassemble your device, follow instructions 6 to 2 in reverse order.
