Einleitung
Replacing a battery is a simple process, but be careful when handling the battery. A damaged battery is highly toxic, so keep safe if you notice any physical damage to your battery.
Was du brauchst
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
Place a fingernail in the slot at the bottom edge of the battery.
Pull the battery out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
