Zum Hauptinhalt wechseln
LG K7 Charging Port Replacement
Was du brauchst
  1. LG K7 Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 2 LG K7 Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: Schritt 5, Bild 1 von 2 LG K7 Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team S3-G2, Harley Fall 2019 Mitglied von IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 556
