Einleitung
A malfunctioning headphone jack is often the problem if you are experiencing a lack of audio through headphones. Replacement headphone jacks can be found online.
Was du brauchst
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
Place a fingernail in the slot at the bottom edge of the battery.
Pull the battery out.
Remove the nine frame screws with a #J00 screwdriver.
Pop the camera button frame off with a spudger. The home button should come off along with the frame.
Line up a plastic opening tool underneath the headphone jack and hold the main body of the phone down.
Lift or the plastic opening tool to separate the headphone jack from the main body of the phone.
2 weitere Personen haben diese Anleitung absolviert.
