Einleitung
Sometimes the battery of a phone no longer works due to various reasons. Replacing the battery is simple and this guide will demonstrate how to do so. Make sure the phone is turned off before removing the battery.
Was du brauchst
Flip the LG K7 over so that the back of the phone is facing up.
Locate the small notch on the bottom left side of the phone.
Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
