Zum Hauptinhalt wechseln
LG K7 T-Mobile Motherboard Replacement
Was du brauchst
  1. LG K7 T-Mobile Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 LG K7 T-Mobile Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 LG K7 T-Mobile Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: Schritt 5, Bild 1 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 5, Bild 2 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: Schritt 6, Bild 1 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 6, Bild 2 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: Schritt 7, Bild 1 von 2 LG K7 T-Mobile Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: Schritt 8, Bild 1 von 2 LG K7 T-Mobile Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: Schritt 9, Bild 1 von 2 LG K7 T-Mobile Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: Schritt 10, Bild 1 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 10, Bild 2 von 3 LG K7 T-Mobile Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G5, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 2,164
