Zum Hauptinhalt wechseln
LG K7 Volume & On/Off Buttons Replacement
Was du brauchst
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: Schritt 1, Bild 1 von 2 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: Schritt 1, Bild 2 von 2
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: Schritt 3, Bild 1 von 1
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: Schritt 4, Bild 1 von 1
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: Schritt 5, Bild 1 von 3 LG K7 Volume & On/Off Buttons Replacement: Schritt 5, Bild 2 von 3 LG K7 Volume & On/Off Buttons Replacement: Schritt 5, Bild 3 von 3
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: Schritt 6, Bild 1 von 1
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jack Lepkowski
136 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G2, Harley Fall 2019 Mitglied von IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 513
