Einleitung
This guide shows how to disassemble and transfer the internal components of a LG K92 to a replacement display with a frame preinstalled. The parts used are a replacement screen installed into a frame, this is the most cost effective method, using just the display without a frame is not advised.
Einführungsvideo
Heat the plastic back panel with a heatgun or heating pad.
Use a thin metal pry tool or razor to separate the adhesive from the frame, and peel the back cover off.
Remove 8 more identically sized phillips screws from the lower antenna and speaker panel.
Pop the lower panel off with tweezers, it should come off relatively easier than the previous panel.
Remove the main logic board by pulling from the top and lifting it out.
Remove the single Phillips screw from the charging daughterboard, and pull it out of the frame.
Gently pull the pressure connection pad up from the frame, then work the ribbon out from the trench.
Using tweezers or a bent pry tool, push the buttons out from inside of the frame.
Use a heating pad to warm the device from the front, apply generous amounts of alcohol to the battery compartment and carefully lift it out.
Remove protective plastics from the replacement frame.
Reinstall components in the order in which they were removed. Be sure to align the antenna wires carefully to prevent pinching issues.
Reinstall remaining components and tighten screws in their respective locations.
4 Kommentare
Why is there no reassembly guide?
Follow the steps in reverse order.
NFC coil, it is not a wireless charging coil despite being similar in appearance.
