Einleitung
Your carrier most likely provided a SIM card to be installed in your phone, which will store your account information. Before using the phone, you will need to install this component.
Begin by taking the back battery cover off.
Put your index finger on the white notch and apply pressure.
While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
Remove the battery.
Put your index finger in the notch above the battery near the top of the casing.
While applying pressure against the battery, lift up and take out the battery.
Remove the SIM card from its housing.
Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
After it is out of the metal housing, it is free to be removed.
